查看: 1296|回复: 2
金盾网 查询违章 网页被黑了?打开是这样的。是今天这样?
发表于 2010-2-6 14:09:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Error 404--Not Found
From RFC 2068 Hypertext Transfer Protocol -- HTTP/1.1:
10.4.5 404 Not Found
The server has not found anything matching the Request-URI. No indication is given of whether the condition is temporary or permanent.
If the server does not wish to make this information available to the client, the status code 403 (Forbidden) can be used instead. The 410 (Gone) status code SHOULD be used if the server knows, through some internally configurable mechanism, that an old resource is permanently unavailable and has no forwarding address.
发表于 2010-2-6 21:33:02 | 只看该作者
经常啦
发表于 2010-2-6 22:55:12 | 只看该作者
服务器也是五天工作制,关掉后自然查不到。
GMT+8, 2025-6-3 18:00 , Processed in 0.018936 second(s), 16 queries .
