查看: 1692|回复: 6
车载电脑升级精品之Sony XA-300Auxiliary Input Adap
发表于 2007-3-27 06:43:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我不善英文,只明其理,无法翻译~!英文资料,大家将就看吧~!
This unit features two RCA inputs for standard devices, MP3 players, Tape Decks, Non-Sony Audio & Video gear, video game systems, etc. One USB port for connection of a computer, which might be used for standard audio or DVD playback. One headphone port with variable level adjustment, this allows the person listening to the headphones to listen to a differnent source than the main cabin in certain situations, such as a child watching a DVD movie if you should install a DVD player and display.
Description from Crutchfield:
Features
General Overview: The XA-300 Aux-In Selector accepts input from a UniLink CD/MD changer and up to two non-UniLink auxiliary sources (DVD player, video game, portable CD, MD, tape or MP3 player). In addition, the unit has a USB input to connect a laptop computer with a USB port. It also has a headphone output with volume control. The XA-300 has a UniLink output connection and stereo RCA outputs to connect the Aux-In Selector module to a Sony changer controller head unit, and allows the head unit to select input from the CD/MD changer or any of the auxiliary sources. (A 2-meter UniLink cable and a 2-meter stereo RCA patch cord is included). The unit requires no external power source because it receives power from the head unit.
AUX Input Connections: The input for each auxiliary source is a set of female RCA jacks mounted directly to the Aux-In Selector module. A stereo RCA patch cord should be connected to the AUX IN jacks on the module and run to where the auxiliary source will be located. If the aux source has a mini-jack output, a stereo mini-jack to dual male RCA cable (item 137ACW339) will be needed instead of a standard RCA patch cable.
USB Input: The USB input allows you to connect a laptop computer to your car stereo system (USB cable not included) in order to play MP3 files or other audio from the computer. The computer must have a compatible operating system in order to work. It must be running Windows 98 Second Edition, Windows ME, Windows 2000, or Mac OS 8.6 or later. (Sony recommends Windows 2000 or Mac OS 9.0 or later)
Selecting The Auxiliary Device: On the Sony changer controller head unit, press "SOURCE" repeatedly until "CD" is selected. Press "MODE" repeatedly until the device you want to listen to is selected. The head unit will cycle through each unit in the following order: CD1 (CD/MD changer) > CD2/AUX1 > CD3/AUX2 > CD4/USB. When CD1 is selected, the CD/MD changer will automatically start playing. When any other source is selected, playback of that unit will have to be manually started and the volume adjusted. As the volume settings of each connected device may differ, the volume of each device should be set to a similar level as the CD/MD changer.
Headphone Output: A stereo mini-plug headphone output with volume control is provided for the private listening of the auxiliary source connected to the AUX IN 1 input. The headphone output is always on, even if the head unit has selected one of the other sources. This allows a passenger to listen to the AUX IN 1 source while the head unit plays another source. (Headphone listening is not recommended while operating the vehicle)
Inputs and Outputs
Front of Unit:
Headphone Output: stereo mini-plug jack with volume control (for private listening of unit connected to Aux Input 1)
Aux Input 1: stereo RCA input (to connect a portable unit)
Aux Input 2: stereo RCA input (to connect a portable unit)
USB Input: for connecting laptop computer with USB Port
Rear of Unit:
Output: UniLink output and stereo RCA output (to Sony changer controller head unit)
Input: UniLink input and stereo RCA input (to connect UniLink CD/MD changer)
migration file (1000 Bytes, 下载次数: 9)
发表于 2007-3-30 13:11:00 | 只看该作者
RE:车载电脑升级精品之Sony XA-300Auxiliary Input Adap
自己改过一台原装日本风度的音响,把旧的主机拆下来换阿而派主机,部旧机因为是为日本本土设计的,收音机频宽很窄.在所有东西都齐全下,并且是有书面指南一步一步拆个中控,搞了2个钟,里面的接线很麻烦,我想我以后没必要都不敢再玩拆中控了,连档位的饰版都要拆下来.
:【 在eldan-chen的大作中提到:】
:【(eldan-chen)回复(KAKA)的大作】
:呵呵,我的理解不过是CAR PC和汽车音响主机的连接问题处理吧.
发表于 2007-3-27 23:49:29 | 只看该作者
你还是得解决目前国内平面屏幕质量不过关的问题,还得解决CAR PC本机的问题.
最大的问题是:如何安装一个适合自己车型的屏幕,时下多数新型车辆的仪表台都是一体化,缺少改装配件,这才是最大的问题.
发表于 2007-3-27 17:08:51 | 只看该作者
:【 在醉猫的大作中提到:】
:我不善英文,只明其理,无法翻译~!英文资料,大家将就看吧~!
:This unit features two RCA inputs for standard devices, MP3 players, Tape Decks, Non-Sony Audio & Video gear, video game systems, etc. One USB port for connection of a computer, which might be used for standard audio or DVD playback. One headphone port with variable level adjustment, this allows the person listening to the headphones to listen to a differnent source than the main cabin in certain situations, such as a child watching a DVD movie if you should install a DVD player and display.
好东西...完美的Carpc,高品质的影音系统合而为一的解决方案...,
Sony 这条恐龙也看中这个市场了....
发表于 2007-3-27 16:49:37 | 只看该作者
【(Zpeter)回复(醉猫)的大作】
这个东东你还有吧,有的话一定留一个给我用!
<IMG SRC="/images/face/179.gif"><IMG SRC="/images/face/179.gif">
发表于 2007-3-27 15:23:06 | 只看该作者
:【 在KAKA的大作中提到:】
:【(KAKA)回复(醉猫)的大作】
:这两个特点合组标准装置投入,球员的MP3、磁带桥面,非音像索尼齿轮、 游戏系统等港口之一的USB连接电脑, 它可用于录音或标准的DVD播放. 耳机港口之一变一级调整 这使听的人听的耳机一比differnent来源主要座舱在某些 情况,如小孩看电影,如果你要安装的DVD影碟机及展示. 从crutchfield描述:特点概况: 在141D300奥克斯在投入了选择接受unilink影音/海事兑换长达两个非unilink辅助来源(DVD播放、 游戏机、便携式影音、海事、录音带或MP3播放). 此外,部队已经投入一个USB连接手提电脑与USB的港口. 它还具有耳机输出量控制. <141-300输出方面有着UNILINK互助、立体声输出连接奥克斯在选择一个模块索尼 换头控制器股 主管单位选择,允许从光盘输入/海事兑换或辅助来源. (二公尺UNILINK电缆、二公尺立体声互助补丁脊髓在内). 该股因为它不需要外部电源获得电力从头部股. 奥克斯输入连接: 每投入来源是一套辅助唧女互助会展开直接向奥克斯在选择模块. 立体标线应连接补丁的奥克斯在唧的模块,跑到那里 将设置辅助来源. 如果奥克斯酝酿一场小型千斤顶产量 立体小杰克为双合男有线(项目137ACW339)将需要一个标准,而有线互助补丁. USB的投入: 让您的USB输入手提电脑接驳车贵立体声系统(不包括USB接口电缆) 为了发挥MP3音乐从电脑或其他音频. 必须有相容的电脑操作系统为工作. 必须视窗98第二版、视窗我,视窗2000,或MACOS8.6或以后. (索尼建议视窗2000或MACOS9.0或以后)选择辅助装置: 关于索尼兑换控制器组组长、新闻"源"反复直到"裁"报关. 新闻"模式"反复直到器件是想听听你挑选. 主管单位将在以下各单位经周期为: CD1的(光盘/海事兑换)>cd2/aux1>cd3/aux2>cd4/usb. 当CD1的报关、裁/海事换将自动开始玩. 当有其他来源的报关、回放,单手将要开始的数量调整. 由于每个连接器设置数量不一, 每个装置量应定为同类级裁/海事兑换. 耳机输出: 一个立体声迷你插头与耳机输出量控制提供了私人聆听接上辅助来源 奥克斯在投入了1. 耳机输出始终,即使已经选定组长单位之一的其他来源. 这使乘客在听取了奥克斯1组组长源而扮演另一个来源. (耳机听而不是营运车辆推荐)投入和产出门前股:耳机输出: 立体声迷你插头与杰克量控制(私人单位连听奥克斯投入1)奥克斯投入1: 互助立体声输入(接驳便携式股)奥克斯投入2: 互助立体声输入(接驳便携式股)的USB输入: 笔记本电脑的USB连接港口与后方单位:产量: unilink产量、产值立体声互助(索尼兑换控制器组组长)投入: unilink投入和立体声互助输入(连接unilink影音/海事兑换)
<IMG SRC="/images/face/135.gif"><IMG SRC="/images/face/135.gif"><IMG SRC="/images/face/135.gif"><IMG SRC="/images/face/135.gif">
发表于 2007-3-27 11:22:31 | 只看该作者
【(KAKA)回复(醉猫)的大作】
这两个特点合组标准装置投入,球员的MP3、磁带桥面,非音像索尼齿轮、 游戏系统等港口之一的USB连接电脑, 它可用于录音或标准的DVD播放. 耳机港口之一变一级调整 这使听的人听的耳机一比differnent来源主要座舱在某些 情况,如小孩看电影,如果你要安装的DVD影碟机及展示. 从crutchfield描述:特点概况: 在141D300奥克斯在投入了选择接受unilink影音/海事兑换长达两个非unilink辅助来源(DVD播放、 游戏机、便携式影音、海事、录音带或MP3播放). 此外,部队已经投入一个USB连接手提电脑与USB的港口. 它还具有耳机输出量控制. <141-300输出方面有着unilink互助、立体声输出连接奥克斯在选择一个模块索尼 换头控制器股 主管单位选择,允许从光盘输入/海事兑换或辅助来源. (二公尺unilink电缆、二公尺立体声互助补丁脊髓在内). 该股因为它不需要外部电源获得电力从头部股. 奥克斯输入连接: 每投入来源是一套辅助唧女互助会展开直接向奥克斯在选择模块. 立体标线应连接补丁的奥克斯在唧的模块,跑到那里 将设置辅助来源. 如果奥克斯酝酿一场小型千斤顶产量 立体小杰克为双合男有线(项目137acw339)将需要一个标准,而有线互助补丁. USB的投入: 让您的USB输入手提电脑接驳车贵立体声系统(不包括USB接口电缆) 为了发挥MP3音乐从电脑或其他音频. 必须有相容的电脑操作系统为工作. 必须视窗98第二版、视窗我,视窗2000,或MacOS8.6或以后. (索尼建议视窗2000或MacOS9.0或以后)选择辅助装置: 关于索尼兑换控制器组组长、新闻"源"反复直到"裁"报关. 新闻"模式"反复直到器件是想听听你挑选. 主管单位将在以下各单位经周期为: CD1的(光盘/海事兑换)>cd2/aux1>cd3/aux2>cd4/usb. 当CD1的报关、裁/海事换将自动开始玩. 当有其他来源的报关、回放,单手将要开始的数量调整. 由于每个连接器设置数量不一, 每个装置量应定为同类级裁/海事兑换. 耳机输出: 一个立体声迷你插头与耳机输出量控制提供了私人聆听接上辅助来源 奥克斯在投入了1. 耳机输出始终,即使已经选定组长单位之一的其他来源. 这使乘客在听取了奥克斯1组组长源而扮演另一个来源. (耳机听而不是营运车辆推荐)投入和产出门前股:耳机输出: 立体声迷你插头与杰克量控制(私人单位连听奥克斯投入1)奥克斯投入1: 互助立体声输入(接驳便携式股)奥克斯投入2: 互助立体声输入(接驳便携式股)的USB输入: 笔记本电脑的USB连接港口与后方单位:产量: unilink产量、产值立体声互助(索尼兑换控制器组组长)投入: unilink投入和立体声互助输入(连接unilink影音/海事兑换)
GMT+8, 2024-12-3 11:53 , Processed in 0.029041 second(s), 19 queries .
