补点这车的资料:
BRAKES - TOYOTA COROLLA ASCENT 4D Hatchback - 4 auto
Front Brakes Ventilated discs, 255mm
- Front calipers Single piston
Rear Brakes Discs
- Rear calipers Single piston
Load sensing proportioning valve STD
Anti-Skid Brakes (ABS) O/PAK
- Number of channels 4
- Number of sensors 4
- ABS operation All wheels
- Electronic Brake-force Distribution O/PAK
- Brake Assist O/PAK
DIMENSIONS - TOYOTA COROLLA ASCENT 4D Hatchback - 4 auto
Length (mm) 4175
Width (mm) 1695
Height (mm) 1470
Wheelbase (mm) 2600
Front track (mm) 1480
Rear track (mm) 1460
Approach Angle (Degrees) N/A
Departure Angle (Degrees) N/A
Breakover / Ramp over angle (Degrees) N/A
Maximum wading depth N/A
Drag co-efficient (Cd) 0.31Cd
Front seat headroom (mm) 945
Rear seat/2nd row headroom (mm) 940
Front seat legroom (mm) N/A
Rear seat/2nd row legroom (mm) N/A
Front seat shoulderroom (mm) 1430
Rear seat/2nd row shoulderroom (mm) N/A
Front seat hiproom (mm) N/A
Rear seat/2nd row hiproom (mm) N/A
DRIVETRAIN - TOYOTA COROLLA ASCENT 4D Hatchback - 4 auto
Driven Wheels Front
Transmission description Four speed automatic, electronically controlled with lock-up torque converter
- Transmission code A245E
Gear Ratios - 1st 3.643:1
- 2nd Gear 2.008:1
- 3rd Gear 1.296:1
- 4th Gear 0.892:1
- Reverse Gear 2.977:1
- Transmission control Electronic
Differential ratio 2.962:1
ENGINE - TOYOTA COROLLA ASCENT 4D Hatchback - 4 auto
Engine Code/Name 1ZZ-FE
Engine capacity (cc) 1794
Engine type Petrol
Engine description 4cyl/DOHC/4v
Maximum Power 100kW @ 6000rpm
Maximum Torque 171Nm @ 4200rpm
Number of cylinders 4cyl
Configuration In-line
Valvetrain DOHC
Number of valves per cylinder 4v
- Variable valve timing Timing only
Fuel system EFI
- Fuel type 91 RON ULP
Bore x Stroke 79.0x91.5mm
Compression Ratio 10.0:1
Battery output 12V/
Ignition system Electronic
Fuel economy ADR 81/01 Test standard
- Combined (L/100km) 8.1
EXTERIOR - TOYOTA COROLLA ASCENT 4D Hatchback - 4 auto
Bodycoloured bumper/s STD
Dual headlights STD
Multi-reflector headlights STD
Radiator grille STD
- Black/grey radiator surround STD
Radiator grille insert STD
- Black/grey radiator insert STD
Front spoiler D/F
Bodyside protection mouldings STD
Body coloured mirrors STD
Black door handles STD
Door sash paint blackout STD
Steel wheels STD
Full wheel caps STD
Alloy wheels D/F
Front mudflaps STD
Rear mudflaps STD
Rear spoiler D/F
- Roof level rear spoiler D/F
Rear garnish STD
- Black/grey rear garnish STD
Towbar D/F
Metallic paint OPT
Mica paint OPT
Touch-up paint STD
Stainless steel exhaust system STD
Tool Kit - Small STD
- 15" alloy wheels D/F
FEATURES - TOYOTA COROLLA ASCENT 4D Hatchback - 4 auto
Air conditioning OPT
Rotary heater controls STD
Passenger's vanity mirror STD
- Cover for Passenger vanity mirror STD
INSTRUMENT & CONTROLS - TOYOTA COROLLA ASCENT 4D Hatchback - 4 auto
Power steering STD
Tilt adjustable steering wheel STD
Trip meter STD
Power exterior mirrors STD
Left hand convex mirror STD
Interior Day/Night mirror STD
Intermittent windscreen wipers STD
- Variable intermittent windscreen wipers STD
Rear washer and wiper STD
- Intermittent rear wiper STD
Rear window demister STD
Headlights on - Audible warning STD
Tachometer STD
Transmission gear indicator in dash STD
Low fuel warning lamp STD
INTERIOR TRIM AND SEATING - TOYOTA COROLLA ASCENT 4D Hatchback - 4 auto
Tone on tone interior trim STD
Cloth seat trim STD
- Full seat face cloth trim STD
Moulded door trims STD
Cloth inserts on door trims STD
Moulded headlining STD
Cloth / Textile headlining STD
Floor carpet STD
Floor mats - front seats D/F
Floor mats - rear/2nd row seats D/F
Fully lined luggage area STD
- Under boot lid lining STD
Sunvisors STD
- Vinyl covered sunvisors STD
Driver's footrest STD
Assist grip/s STD
- Fixed type assist grips STD
- Number of assist grips 3
Tailgate/boot assist handle STD
Front bucket seats STD
Sports front seats STD
- Driver's seat single height adjustment STD
Front seat head restraints STD
- Removable front head restraints STD
- Height adjust front head restraints STD
Second Row/Rear seat STD
- Hinged seat base for 2nd row/rear seats STD
- Split-fold 2nd row/rear seat base STD
- Rake adjustable 2nd row/rear seats STD
- 60:40 split fold 2nd row/rear seat back STD
- Outboard headrestraints for 2nd row/rear seats STD
- Centre headrestraint for 2nd row/rear seats STD
- Height adjust headrestraints for 2nd row/rear seats STD
Front Passenger seat - Manual adjustments STD
Driver's seat - Manual adjustments STD
LIGHTING - TOYOTA COROLLA ASCENT 4D Hatchback - 4 auto
Interior dome light/s STD
- Number of dome light/s 1
- Auto-off dome light/s with delay STD
- Map light/s STD
- Front seat map light/s STD
Luggage/cargo light STD
SAFETY - TOYOTA COROLLA ASCENT 4D Hatchback - 4 auto
Global Outstanding Assesment body (GOA) STD
Driver's SRS airbag STD
Front passenger SRS airbag O/PAK
Driver's pre-tensioner seatbelt STD
Driver's forcelimiter seatbelt STD
Front passenger forcelimiter seatbelt O/PAK
Driver's seatbelt warning lamp STD
Height adjustable front seatbelts STD
2nd row/rear seat ALR outboard seatbelts for child seat/caps STD
Side door anti-intrusion beams STD
High-mount rear stop lamp STD
Tailgate/boot ajar warning lamp STD
- Electronic Brake force Distribution (EBD) O/PAK
- Brake Assist (BA) O/PAK
Front passenger pre-tensioner seatbelt STD
Auto trans shift interlock STD
Door ajar warning STD
Toyota Safe-T-Cell STD
SECURITY - TOYOTA COROLLA ASCENT 4D Hatchback - 4 auto
Engine immobiliser STD
Central locking / Power door locks STD
- Remote/Keyless central locking STD
Cargo cover STD
Remote fuel lid release STD
Fuel cap holder or tether STD
Security coded radio STD
- Includes boot/tailgate unlock with central locking STD
SOUND SYSTEM - TOYOTA COROLLA ASCENT 4D Hatchback - 4 auto
AM/FM Radio STD
Electronic tune radio STD
Number of speakers 4
CD socket/compatability STD
CD player STD
- Single CD player STD
- CD changer in cabin D/F
- 6 Disc CD changer D/F
Aerial - Roof mounted STD
Aerial - Centre line of roof STD
Aerial - Fixed height type STD
STEERING - TOYOTA COROLLA ASCENT 4D Hatchback - 4 auto
Steering type Rack and pinion
Steering operation Power assisted
Turning Circle at Kerb 9.8m
Turns lock to lock 3.29
STORAGE - TOYOTA COROLLA ASCENT 4D Hatchback - 4 auto
Glovebox STD
Storage pocket/tray STD
- Driver's side storage under dash STD
- Dashboard centre storage bin STD
- Dash centre storage bin with lid STD
- Coin tray/holder STD
- Full centre console STD
- Storage box in centre console STD
- Storage box lid in centre console STD
Door pockets - Front STD
Front ashtray STD
Rear ashtray(s) STD
Cigarette lighter - front STD
Cup holder/s STD
- Number of cup holder/s 2
- Moulded type cup holder/s STD
- Cup holder/s at centre console STD
- Cup holder/s with cover/s STD
Coathooks - number of 2
Centre console STD
SUSPENSION - TOYOTA COROLLA ASCENT 4D Hatchback - 4 auto
Front Suspension Independent, MacPherson strut, lower L- arm, off-set coil springs, gas damper units and ball joint mounted anti-roll bar.
Rear Suspension Semi-independent, trailing torsion beam, strut type coil spring, gas damper units and enclosed anti-roll bar.
VEHICLE COMMUNICATIONS - TOYOTA COROLLA ASCENT 4D Hatchback - 4 auto
Satellite navigation system D/F
WARRANTY / SERVICE - TOYOTA COROLLA ASCENT 4D Hatchback - 4 auto
Paint in years 3
Perforation in years 5
Vehicle in years/kilometres 3yrs or 100,000kms (whichever occurs first)
WEIGHTS & CAPACITIES - TOYOTA COROLLA ASCENT 4D Hatchback - 4 auto
Kerb Weight (kg) 1100-1190
Gross Vehicle Mass (kg) 1630
Gross Combined Mass (Kg) N/A
Maximum roof load (Kg) N/A
Seating capacity 5
Luggage capacity (litres) 271 litres (VDA)
Luggage capacity - rear seat down (litres) N/A
Cargo volume N/A
Maximum load length (mm) N/A
Maximum load width (mm) N/A
Maximum load height (mm) N/A
Distance at wheelarch (mm) N/A
Towing capacity - with trailer brakes 950kg
- Without trailer brakes 450kg
Fuel Tank Capacity (litres) 55 litres
